It is currently Mon Jul 21, 2025 10:57 am
PostPosted: Fri Feb 09, 2007 4:56 am
I have taken Dave and Colin's advice and pick up a Makita 3707 lam
trimmer and after much worrying about it decided today would be
binding channel day.
I decided to make a jig to make the trimmer run parallel to the sides of
the guitar (which i spent quite a while scraping and sanding true).
Unfortunately my workshop is also my bedroom so i thought i'd go
outside to do the dirty work. Unfortunately again it's snowing here and is
pretty cold at the moment so i had to improvise a little shelter!
This is the little jig in knocked up - it looks a little bit shoddy bit it is
precise where it counts and quite sturdy.
Here are the results after extending the neck channels with a razor saw
and cleaning up with a file.
The keen eyed ones of you (that everyone right?) may spot my beginners
mistake of not cutting the back braces thin enough - as a result they
stick up out of my channels slightly - think i might have to chisel the
spruce out and fill the gaps with epoxy and RW dust - is there a better
way?
All in all i was very pleased with how it has turned out - there was zero
chip-out maybe this is because varnished the edges prior to cutting with
a stewmac piloted router bit - which seemed to make a much cleaner cut
than the downcut bit i tried before.
Last but in no way least i want to say a big thank you to all those that
have offered help and assistance so far - it's great knowing there is so
much support for first time builders in the OLF!
Take care,
John.
PostPosted: Fri Feb 09, 2007 5:15 am
Thats dedication to the pursuit alright, and a job well done - good on you!!!!
I cant wait to see the finished pics!!
Charliewood
PostPosted: Fri Feb 09, 2007 5:20 am
John,
That's a great lam trimmer - you won't regret buying it I'm sure. Neat adaptation and that's a great job for first binmding/purfling channels - it looks really clean. The snow is fun isn't it
I'm not sure what your problem with the back braces is - your binding is going to sit in your channel and cover it all up when you glue in the binding/purfling isn't it? Maybe a closeup photo of your "problrm@ would help me better.
PostPosted: Fri Feb 09, 2007 5:31 am
Last Name: Abercrombie
John-
Nice job on your first binding ledge!
I think I understand your problem with the braces....the braces were 'too tall' so the binding ledge didn't cut them off completely?
I would avoid trying to chisel and fill with sawdust unless absolutely necessary.
Can you cut the binding recess bigger and use a wider binding strip? This might be easier even if you have to source/make some wider bindings, and will certainly look cleaner than a fill job.
I may not understand the problem,though...
PostPosted: Fri Feb 09, 2007 5:34 am
Hi John, I love your garden shop and the climate control system!!
"Where there's a will there's a way"!!
The the guitar is looking really good. Two things you could try to do to
fix where the brace ends show...
1. If the binding is wide enough you can just cut the ledge a little wider,
or add a purfling line to make the binding wider... one of these would be
the best I think. or...
2. When you chisel out the brace ends fill the holes with little pieces
made from scraps from the rosewood, (if you have some scraps).
Keep up the good work!
Long
PostPosted: Fri Feb 09, 2007 6:31 am
I'm unable to take a photo so here is a diagram of the problem - the red
thing being the brace.
If i make the channel deeper then i will have to cut a thin strip of binding
and glue it to the existing binding to increase the depth. Any tips for this?
John.
PostPosted: Fri Feb 09, 2007 6:45 am
As Bob suggested, you could add purfling (WBW or similar). There's lots of info in the various archives about pre-bending purfling while sandwiched with binding. Some of the fiber purfling is quite flexible.
Less trouble would be to make or buy some wider binding strips, using your original plan.
If you glue anything in next to your binding, make it contrasting, or it will look like a 'patch job'.
Remember the old adage: "Pros know how to hide their mistakes better than beginners."
PostPosted: Fri Feb 09, 2007 6:54 am
Add side purfling lines.
PostPosted: Fri Feb 09, 2007 8:09 am
Ok got it. I don't usually let the braces go all the way through the sides, stopping them short in pockets in the linings. Side purfling would be the way to go.
PostPosted: Fri Feb 09, 2007 8:24 am
I should have mentioned that my banding is curly maple/B/W/B so i
already have side purfing. I'm toying with the idea of sticking a strip of
ebony on to make up the height.
john
PostPosted: Fri Feb 09, 2007 8:35 am
John,
How tall is your maple binding with the bwb? Or put it another way, if you were to route out the binding channel to get rid of the braces and have a continuous side line all around how tall a binding/side purfling strip would you need? I have some tall maple with bwb binding that might work for you.
The ebony would look bitty I think. Another alternative would be to chisel out the brace ends and glue some small Rosewood pieces in from side/back offcuts matching the grain/colour as best you can. Make them so that they stick up slightly into the binding channel, when the glue is dry scrape them flush with the sides and then re-route the binding channel over them to make them flush. This will look much better than dust/glue fill and as the wood is a dark one they should be pretty invisible.
PostPosted: Fri Feb 09, 2007 9:15 am
Dave, the binding channel have is 6mm. The biggest gap is about 3mm
so i need 9mm. 10mm to be on the safe side.
Best wishes,
John.
PostPosted: Fri Feb 09, 2007 9:55 am
Great job, glad you like the Makita, I'm very impressed with your dedication in the snow.
I think 3mm is too wide for side purfling alone to cover and look right, I'd use a wider binding and then a narrow purfling. Save the stuff you've got for the next guitar. A contrasting purfling may look too much at 8-9mm so I'd do it in a dark wood Ebony or rosewood with just a narrow BWB purfling.
If you call David Dyke I'm sure he'll sort you out with wider bindings. If not PM me I'm sure I've got some rosewood I can cut for you.
PostPosted: Fri Feb 09, 2007 9:57 am
By the way, like Dave I only inlet my braces into the linings not the sides themselves.
PostPosted: Fri Feb 09, 2007 10:41 pm
John,
The maple bwb binding I have is 8.4mm deep and 2.2mm wide, so this might not be deep enough for you. In which case it's either fill the bracing gaps with Rosewood or get some new deeper binding.
PostPosted: Fri Feb 09, 2007 10:57 pm
Thanks for checking Dave, I'll see what i can do with what i have here and
post my progress.
best,
john.
PostPosted: Sat Feb 10, 2007 12:36 am
First name: Jim
Last Name: Kirby
Hesh - John's picture about 1/2 way down shows the problem.
He let the braces all the way through the sides, and then the binding channel isn't tall enough to cover the ends.
Wider bindings, definitely.
Jim
Jim Kirby
kirby@udel.edu
PostPosted: Sat Feb 10, 2007 2:07 am
I'm really impressed, great work and dedication, you are one person who learns quick and this guitar will be a canon! Love that rosette and wood combo!
